I know this sounds silly, but check to see that it plugs in completely when you put the headlight assembly in. On mine, the plastic that holds the headlight harness in place broke slightly loose from the mount and I had the same issue. To get it working, I slid the headlight on the track as far back as I could and reached my hand into the opening to plug it in the back of the headlight assembly. Another thing to check is the main ground for that side. It's located inside the trunk area, you'll see several brown wires going to a stud that sticks out of the side wall just opposite of the headlights. Let me know if this works for you. Good luck!
