Old 07-05-2008, 09:15 AM   #1
Quickurt
Quickurt's Avatar
Originally Posted by jhandy
I have aftermarket wheels that required me to put 7mm HR spacers on all four corners. The (rear) wheel's rim only clears the strut shaft by 2mm. I plan on instaling the HR sport springs with a 1-1.5 inch drop.
What do you think will happen with my clearence issue? Will it be closer to the tower? Will I have to get larger spacers?
Thanks for the help,
James
With only 2mm clearance between rim/strut, you may get more tire flex that that on hard cornering. It may or may not be enough rub to damage the tire, but it will put sufficient heat into the shock to effect it's performance.
I mention this for your safety and the possibility of handling "coming and going."
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
