Originally Posted by CJ_Boxster
... do you get a shimmy from the rear end of your car til both rear wheels have even weight loads on them/are flat on the ground again...If so then your Toe isnt up to spec anymore, you'll need an alignment
CJ,
Don't want to hijack this thread and I don't go around smoking my tires all the time but, is a symptom of poor alignment also wheel hop on heavy acceleration?
In less than ideal conditions, if I make any effort to smoke the tires, the back hops all over the place. It also does this a bit powering out of a turn to (my sign that pushed it to the it to the edge).
Regards, PK
