Old 07-01-2008, 04:15 PM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by joshua6060
I recognize the difference in the tires but there is no way that should cause my rear end to get loose in the rain going 55mph in a straight line.
I'm leaning toward the alignment being off.....
A good way to tell if its your alignment's fault, in dry weather when you go over a bump in the road, with 1 or the other rear wheel, do you get a shimmy from the rear end of your car til both rear wheels have even weight loads on them/are flat on the ground again?
If so then your Toe isnt up to spec anymore, you'll need an alignment
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
