Old 03-14-2005, 07:55 PM   #25
phrankandbeanz
Send a message via AIM to phrankandbeanz
If you are doing a litronic retrofit(pretty sure that is what you are doing), you can just slide the original amber front headlights out and just insert the litronic ones in. If you don't do the wiring, all you are losing is the ability for the litronic lights to rotate a few degrees up when you turn on your highbeams. That feature wasn't importnat to me, so I just plugged and played without doing any wiring. It is great. The side markers, is a simple screw inside the wheelwell. Done in 15 minutes. The rear like someone previously stated can be done in another 15min. The plug and play can be done in 5 minutes.
Your dealer is ripping you off. Go online or call brandywine porsche yourself and get the litronics for 1200 and just plug it in yourself. I believe the rear clears are like 200 from the brandywine but dont quote me on it. Also the smoked side markers are like another $30. You are more then capable of doing all the installs yourself.
phrankandbeanz is offline   Reply With Quote
