The male connector you can buy from BMW or Porsche. BMW part number is 61 13 6 909 058. Porsche part number is 999 650 513 40.
You also need 5 VW wires. Assuming you have a 1997-2000 use three 000 979 009 and two 000 979 010. The wires you have to buy from VW not Porsche.
You also need to crimp on something to the ground wire. It goes by different names. Eyelet or ring terminal. 22-18 wire size. 1/4" or 6 mm stud size.
You also need something to connect the spliced wires together. I forget what they are called, or you can just solder them.
