Old 06-16-2008, 10:22 PM   #2
Lil bastard
Lil bastard's Avatar
Red face
WHOA !!
Before you go throwing $49 or whatever at it, be sure that's the issue!
Just because someone else got 'X' to fix it does NOT mean that's the same issue.
P0302 is a misfire on the number 2 cylinder. The Factory repair manual lists causes as:
  • 1. Fuel Tank driven to empty - triggers CEL, but no fault registered or existing.
    2. Contaminated, faulty or wrong spark plug - $6 not $49.
    3. Contact resistance - such as a leaky Spark Plug Tube 'O' Ring - $2.
    4. Loose connections - Check to see that CoilPak is properly seated on the Plug and that it's electrical connector is tight, not corroded or oil soaked.
It does not list a faulty Ignition Coil as a possible cause - to eliminate, check Resistance between terminal 1 and 15 on the coil look for 0.3 - 0.7 Ohms @ 20 °C.
One thing you do NOT want to do is remove the CoilPak and see if you can get a spark to arc to the block - this can fry the DME or CoilPak.
Do these checks, then by process of elimination select the proper fix.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
