Old 06-08-2008, 12:08 PM   #4
RandallNeighbour
Well, boys and girls, I'm going to have to bow out on the trip this year. I was going to grin and bear it on the outrageous fuel costs and the tire wear getting there and back, and then Hans' diagnosis of my worn suspension squashed it financially for me. I need about $3000 worth of work on the car, and a chunk of that is what I had saved up for the trip.
I need wheel bearings (both sides) and one control arm up front, and a control arm in the back (it's creaking). The struts up front are original and since Hans has to tear down the wheel carrier to swap out the bearing, it makes common sense to replace the struts while I'm at it.
Hans made another good point as well. He is recommending I replace the trailing arms as well in the back because they're original as well and go out on cars of my age and mileage. Add to that another lower control arm because it's original as well and it will go out sooner than later like the other, and the price rises even more.
Since struts up front will cost about $500 for Bilstein HD's I think I'll just get a set of KSport coilovers and have him install them while he's in there.
All I can say is that I will miss seeing you all and driving with you, but there will be other trips. I've fretted over my worn suspension for a long time, so this should get it in good shape for the long haul and I won't have to worry what's going to go out next on this car (except for the intermediate shaft, the transmission, the RMS, and the top transmissions!)
Ah, the joys of owning an old Boxster just keep piling up, eh? :ah:
