Old 06-05-2008, 03:53 PM   #2
insite
Originally Posted by 23109VC
so if I can find a used boxster that already has the M030 suspension upgrade from the factory - is it really worth it to upgrade to ROW M030???
or is the difference so subtle that you woudln't really notice it???
I have driven a base boxster with "regular" suspension and the M030 suspension and I *could* tell the difference between that. not sure if the ROW M030 would change stuff enough to notice? maybe just the ride height woudl be visibly noticeable???
the ride between the US and RoW M030 packages is nearly identical. the only difference is that the RoW version has a lower center of gravity. i also think the lower ride height looks better. it's up to you whether you think it's worth it, but all you'd really need to do to make the US car RoW spec would be to swap the springs. they're only about $250, but the labor may be expensive. if you're handy, you can do it yourself.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
