Old 05-25-2008, 06:26 PM   #1
Jaxonalden
Jaxonalden's Avatar
Riding the clutch does two things;
1. If you drive with your foot partially depressed on the clutch pedal, it will engage the throw out bearing on the pressure plate and the throw out bearing will spin with the engine RPM causing premature wear.
2. From the time when the clutch disc touches the fly wheel until it's full engaged and spinning the same RPM's the disc is "slipping". The less time the disc slips the less wear on the disc. (I'm not advocating side stepping the clutch, that's a whole other story)
To answer the original question, if your quick and smooth with your shifts you should be alright. Just a personal thought; There's an old saying that I live by, and being a mechanic all my life I can attest to it;
Double the RPM, triple the wear.
P.S. You like to rev it to the redline? Remember that the computer logs rev limiter and over rev's. My new Durametric scanning tool showed my '04 S was 0/0 on both counters. Good news for reselling and warranty work.
