Old 05-19-2008, 06:32 PM   #11
vipola
Originally Posted by Frank M
Using a small cutoff wheel for the dremel;
You could always cut the nut part-way to get it off the bolt's shaft or just cut the bolt , this if course depends on how much room behind the emblem.
That was the other idea.. Break the Nuts with a drill bit so it will release the pin.. but it's 1/2 inch deep in a hole big like my little finger.. and it can be pretty difficult to work upside down.. :/
vipola is offline   Reply With Quote
