Originally Posted by vipola
Hi Frank, Even with a ScrewDriver, I can't unscrew it.. but I like the idea to do a groove with a dremel to be sure the drill bit won't whipe on the side
Using a small cutoff wheel for the dremel;
You could always cut the nut part-way to get it off the bolt's shaft or just cut the bolt , this if course depends on how much room behind the emblem.
