Old 05-13-2008, 06:28 PM   #5
Sammy
Originally Posted by AddictionRacing
Do you have 8.5" all the way around or are the fronts still 7.5"? It sounds like I should try the 245/ 275 set-up. Thanks for the help, and please keep it coming if you have a different opinion. Once I make my decision and get them mounted up I'll share the results.
I have 8.5" all the way around. I'm not sure a 245 will fit on a 7" wheel but do some searching to find out if anyone has done this? You might also search the following site:
http://boxcar-racing.com/forum/index.php?PHPSESSID=16734c86c80c5b091424f4403ffd2c 66&
In terms of grip I found that between the new tires (granted it could be the compound of the V710's) and the lower stress bar I was dead even with a couple guys that I was 2-3 seconds behind last year. It was a little weird getting use to virtually full throttle through the slaloms. The car was very neutral and much more predictable than before (of course this could be my driving style?).
Sammy is offline   Reply With Quote
