Old 05-13-2008, 04:47 PM   #3
AddictionRacing
Originally Posted by Sammy
I'm running a 245/275 setup with Kuhmo V710's on 17x8.5" wheels. The 275 is a stretch for the 8.5" rim but I am truly impressed with the difference in handling. OMG does the car stick! I don't use spacers but it is a tight fit in the front. The rear could be spaced out a little but I'm not planning to do this because I'm thoroughly impressed with the handling at this point.
Do you have 8.5" all the way around or are the fronts still 7.5"? It sounds like I should try the 245/ 275 set-up. Thanks for the help, and please keep it coming if you have a different opinion. Once I make my decision and get them mounted up I'll share the results.
AddictionRacing is offline   Reply With Quote
