Old 05-09-2008, 10:47 AM   #12
2001saxster
Originally Posted by easyc
If you have oil in your coolant, then the engine is most likely dead... have them run a compression and leak down test to just make sure... the most likely culprit is a cracked cylinder sleeve... they may tell you its a head gasket, but I from my experience with the problem, no one I can find has had a head gasket go out on a M96
They told me it was a shifted cylinder sleeve actually. Sounds like the same thing to me.
2001saxster is offline   Reply With Quote
