Old 05-08-2008, 02:56 PM   #15
ultimate1
Send a message via AIM to ultimate1 Send a message via Yahoo to ultimate1
Thanks again ToolP I bled it like you suggested and so far so good no leaks. I used distilled water and I will drive it a little tomorrow morning and see how she reacts. If no leaks then I will flush and fill with proper coolant.
The temp ran a little just past the 180 mark on the temp gauge, the fan came on and off. Topped off a little and put down the bleed valve and closed her up. The warning light was blinking the whole time while I was bleeding her. Am I to assume that is normal since I did all of this while the car was in my garage? Door open of course.
Here are a few pics of the old water pump
ultimate1 is offline   Reply With Quote
