Old 04-30-2008, 12:11 PM   #2
Tool Pants
The vanes for the impeller broke off. The middle of the impeller, or what is left of it, is still on the shaft. The bearing on this pump is much worse than the bearing on the pump on the left.
The owner of the pump on the left is a local owner. He heard noises and saw coolant on the ground. I told him is most likely the pump. He took it in right away before the bearing got worse, and before the impeller could break into pieces. Since he caught it quick enough he did not throw the belt.
Tool Pants is offline   Reply With Quote
