Old 04-27-2008, 02:18 PM   #3
borisboem
P1502, using parts of another Boxster
Hi Boxster fans, thanks for your replies. Unforgenatly the car is still not running after controlling everything which is said and replacing MAF sensor and throttle.
U know i had this electrical problem with my boxster S. Bad running engine on 1500 RPE max, no gaspedalreaction/acyivity probably caused by giving starthelp to another car. OBDII code 1502 is showing up all the time, maf sensor and throttle body are already replaced. Do u ever heard of problems after giving starthelp?
Do u think its dangerous to use the MAF sensor and throttle body of another boxster. I can use a friends boxster S form 2001, i have a 2000 S, to replace parts and to see whats is the problem. U know i had this P1502 code, replaced MAF and throttle but its still the same problem. I dont want my friend to have problems with his car after that and i am, kind of responsible for that.
I mean about resetting and using different DME's with this parts, is that not risky?
I appreciate if u will reply on this issue cause two different porschecar dealers here in Holland cant find the problem.
Boris
borisboem is offline   Reply With Quote
