Old 04-21-2008, 04:01 PM   #4
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
If you have the standard shift knob (not the upgraded aluminum shifters), all you have to do is use your fingertips to snap off the base of the boot from the center console. Pry it up with your fingers, and it will just pop off. Then, just put the shift lever in 2nd gear, grab the shift handle and just pull the knob towards your chest. It will pop right out, as it is friction fit.
The upgraded knobs utilize a set screw to secure the knob that is located under the knob in the 3rd gear position.
