Old 04-17-2008, 11:41 AM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Try this... With the Ignition on, Remove and re-plug all 3 connectors one at a time, back into the back of your gauge cluster until everything turns back on.
Also try this with the Ignition on and with the left turnsignal engaged... then with the right turnsignal engaged until you locate which Connector isnt seated properly into the back of the cluster.... Keep in mind that if you reinsert & clip them in correctly, you will notice that as you lift the locking cam, the connected till pull itself deeper into the cluster on its own.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
