Old 04-15-2008, 12:15 AM   #12
Benny986
i have 15mm up front w/ a 9.5" wheel.
i have 2 spacers in the back, 15mm on the outside, and a 5mm on the inside of the rotor. also a 9.5" wheel.
do spacers put extra wear on various parts? yes, but about as much as getting different wider wheels. it makes no difference if the wheel had the "spacer" built in or not. image if the spacer was a part of the wheel, vs. being a separate piece. same diff.
anything bigger than 5mm, and i would make sure it was hubcentric. not just for stability and making sure you get no road vibrations, but so that its easier to put wheels on the car.
ohh you will need longer bolts. OR. i put long studs on my car, so i have studs with bolts. similar to Japanese cars.
http://b-ng.com/audi/images/avatar.jpg
Benny
lubrify.com
Benny986 is offline   Reply With Quote
