Old 04-14-2008, 10:37 PM   #2
Cloudsurfer
Just re-read and noticed you said 18x10.5, not 18x10 as I first thought. That, I'm not sure on. I know a few guys are running 10.5s in the rear, but I think you're going to be awfully wide to get enough inner clearance that you'll be either flush with, or outside the fender. Probably fine at stock ride height, and if you're into that look, but if you go to lower you may run into problems.
Patrick
