Old 04-11-2008, 08:30 PM   #4
Sputter
Originally Posted by pteam
Whats the difference between regular coolant and the porsche stuff?
If you mix the two you will likely end up with jello in your system. There are other brands you can use but usually only after a total flush. I don't recall offhand the chemical difference. Check Renntech.org.
There was moisture on the trunk lid above the cap. Can the new style cap that I have still go bad? Wasn't this the point of the "new style" cap was to prevent the problems the "old style" had?
It can. I know I had to swap .01 cap for another .01 once.
-- 02 Boxster S
-- Black/Black
-- Sideskirts/PSE
Sputter is offline   Reply With Quote
