Old 04-08-2008, 08:57 AM   #10
2000SoCalBoxsterS
Originally Posted by heyjae
It's unlikely that the O2 sensors are at fault here. I've read conflicting accounts about changing just the bad O2 sensor versus changing all of them. Personally, I changed all of mine, but my car has 80,000 miles and they'd be getting close to being replaced anyway and because I changed all of them with generic O2 sensors and I wanted to keep all of them from the same brand. Of course, one of the 4 I got was bad and I needed to replace it right away and bought a different type. It seems to work pretty well so far.
Looking for a vacuum leak and/or troubleshooting codes is a PITA. After checking the low hanging fruit (cleaning the MAF--maybe replacing it, doing a visual on the vacuum tubes, oil filler tube, checking the oil cap), either take the car to a competent shop or invest in some diagnostic tools and resign yourself to spending hours learning and a lot of trial and error. The basic ones to look at are the 2 small plastic tubes coming out of the rubber coupling between manifold and intake plenum/resonator. There's one on each side. I thing the one on the passenger side is visible from the top and the one on the driver side is visible from the bottom. Then there are the rubber tubes coming from the throttle body. But a vacuum leak can be from the air oil separator (maybe), the secondary air injection system (less likely) or even the brake booster (not likely). Unless you are pretty handy, I'd defer troubleshooting those to a mechanic. There's also using propane to check for leaks. Others seem to do it fine, but I've only tried that once and was not successful with that method.
As far as a visual of the MAF before cleaning, it's probably a thin layer of oil or dirt that's causing the problem and it'd be hard to see. If you have a code reader that shows intake flow, mine is about 4-5 grams/sec. Another thing to check is your short term fuel trims. It should be within +/- 10% normally at idle, although it can be as high as +/- 25%. With the code you are throwing, yours is probably +25%. When my MAF was going bad, at idle the flow would jump around and the STFT would be erratic as well, but that's just one data point.
Hey HeyJae, thank you for taking the trouble to write such an extensive response. But this is a little over my head though in terms or seeing the values for the MAF /Intake.
My code reader is very basic. All it said was P1128 & P1130. This was with the ignition on and the engine not running. There is another function on it where you do a "MIL" reading and it says for that you have the engine running. But even if I then saw these various values I wouldn't know what to do with them.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
