Thread: lowering spring
Old 02-26-2005, 07:26 AM   #3
jfmillr
jfmillr's Avatar
As far as I know none of the spring will adjust to just one inch shorter, unless you go with an adjustable coilover system. There are a couple out there. I have the Bilstein coilovers, but I have mine setup for most firm and it puts it 2 1/4 inches lower then stock. if you are only looking for springs I beleive none of them will be only 1 inch shorter. I am pretty sure more of the aftermarket springs for our cars are atleast 2 inches shorter. So unless you plan to go with coilovers....good luck with your spring search. H&R springs are really nice...but again shorter then 1 inch. CLoser to 2.
www.09860.com
jfmillr is offline   Reply With Quote
