Old 03-28-2008, 11:01 AM   #2
pk2
Originally Posted by 9eighty6
...Where is this fuse panel in the rear trunk? How can I access it?
Thanks -
Josh
The fuses s in the drivers foot well. The relays for the soiler are on a rack behind the left panel of the trunk, You pull back the side carpet by releasing to little half twist screws. The relay carrier slides out in a weird in a away so don;'t force it..Spoiler relays in question are brown and 3rd in from left, top and bottom.
You can take them out thwack em on the ground, sometimes loosens them up. You can also swap the and see if your problem works in reverse.
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
