Old 03-22-2008, 11:53 AM   #1
yellowboxster01
Originally Posted by Allen K. Littlefield
Does the hood crest have screw off fasteners or are they pulled off? I tried to loosen it by using a flat nose pliers, it freed up a bit but did not release. Is there a mm size to the clamp/nuts as they look hexagonal? Any advice for removal?
AKL
There's one or two 10mm nuts that hold it on. May take a little prying to get the gasket loose after that.
yellowboxster01 is offline   Reply With Quote
