Old 03-09-2008, 03:38 PM   #1
jcskis
Automatic Window Lowering
Thanks for the replies. I finally received the microswitch yesterday and installed it today. Unfortunately, I have the same problem. The window will lower a 1/4 inch when I open the door. But the window does back up as soon as I release either the outer door handle or the inner door handle. If I pull either the outer or inside door handle while the door is open, the window will come down the 1/4 inch. But as soon as I let go, the window goes full up. I've gotten quite good at closing the door while holding the outer handle and letting go as soon as the door closes but I would really like this fixed. Is it possible the new microswitch is bad? When I installed the new microswitch, I noticed that it connected to the outer handle. Is there another microswitch that attaches to the inner door handle that could be causing this problem? I suppose the only other thing this could be is the window regulator. Ideas?
Thanks in advance,
JCSkis
jcskis is offline   Reply With Quote
