Old 02-26-2008, 08:00 PM   #13
rick3000
There Is No Substitute.
rick3000's Avatar
You could try tightening the bolts with the levers latched, but I am not sure if that would do much.
Also, the levers should take some force, but it shouldn't be a lot. If you can't lock them comfortable then there is something wrong. Also, just a general rule, when the allen wrench your using to tighten the bolts can just barely fit between the body and top it is properly spaced.
(Yah! Post 800! )
