Old 02-26-2008, 10:51 AM   #4
chaudanova
Originally Posted by D.L.
I put 19's on my car, and had the same vibration issue. After having it rebalanced on a Hunter road force wheel balancer, it took all the vibration out and it rolls smooth as glass at all speeds. To have the wheels road force balanced should not cost very much. Try that first, and if that's not it, keep problem solving. Road force balance is cheap to do.
DL, just curious, what kind of prices are they charging you in your neck of the woods for the Hunter Road force balancing? Over here, I believe it is around $15 per wheel.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
