Old 02-25-2008, 04:33 PM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by 986Roadster
thank you for the picture. can't i leave it open, why even glue a cup to the end, if it's open anyways. does this make sense. if i get an elblow put on, i am still leaving it open. or am i missing a step. i am pulling the silencer out of the box, so the box is now empty. will i be putting the box back also. dumb questions...i guess when i open, i should be able to figure it out better.
What my directions say todo is to remove and discard part number 6, 7 & 8 completely...
The Epoxy in the cup will be jammed onto the opening circled in the picture... However once the epoxy is cured abit and almost solid, you peal the 2/3rd size cup off and the epoxy should stay behind stuck onto the opening circled in red.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
