Old 02-23-2008, 12:46 PM   #1
renzop
First let me say that everyone is certainly entitled to do what they want with their cars. But it makes me ill to think that people are taking one of the best handling cars on the planet and slamming it.
Your car was designed to have the minimum wheel travel based on car weight, spring rate and expected road irregularities. Basically the worst bump you might hit will compress the suspension almost to the bump stops.
Lowering springs shorten wheel travel. If you reduce wheel travel you have two choices. You can use stiffer spring rates so the worst bump you might encounter still won't hit the bump stops. Or you can use a lighter than needed rate and every once in a while the car will bottom out and hit the bump stops. Lets talk about why both these solutions are bad.
Very stiff spring rates make the car ride like crap. Furthermore your shocks were designed to control the bouncing of the stock rate springs. Putting in higher rate springs without getting shocks designed for those higher rates will lead to poor wheel control. After you hit a bump, the tire will continue to bounce up and down because the shock (or damper) cannot control the spring. Also the overworked shock can overheat leading to premature shock failure.
So what happens if you lower but don't raise spring rates enough? You hit the bump stops. When this happens going straight it will mostly result in you and the car suddenly stopping your downward motion. It will feel like you got hit in the a$$ from below. You probably will not hear anything other than your own cursing because bump stops are rubber or urethane. Of course you might hear your shocks crying for mercy. The easiest way to blow a shock is to bottom it out.
But worse still, is what happens if one corner of the car hits the bump stop when in a turn. Basically, its like the spring rate suddenly went to infinity at that corner. This can lead to extreme and immediate under or oversteer. The car will radically change direction. If this happens you probably won't hear it either; only the crunching of crashed metal.
Lowering the car an inch with lowering springs is fine. More than that and you need to redesign shocks, steering geometry, etc.
Just my opinion. Please don't take offense if you don't agree.
Regards,
Alan
renzop is offline   Reply With Quote
