Thread: clutch failure
Old 02-20-2008, 10:13 PM   #4
Lil bastard
Lil bastard's Avatar
It's often recommended when replacing either hydraulic component of the system (master cylinder / slave cylinder) to replace them both at the same time.
This is because the old part receives added resistance from the new, stronger part and will usually fail in short order.
It does add slightly to the expense, but you save on having only 1 tow and only need to bleed the system once. This also makes the system work 100% new again.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
