Old 02-20-2008, 04:21 PM   #1
Lil bastard
Lil bastard's Avatar
Well, there's no way to tell if you did not measure the lateral runout or put a micrometer on the disc before you started.
The thickness of an OEM Boxster S disc is:
  • front / rear
    28 mm / 24mm
The minimum allowable thickness of an OEM Boxster S disc is:
  • front / rear
    26.0 mm / 22.0 mm
But, the OEM discs, while sometimes supplied by Zimmerman to Porsche for the 'S' model, are not the same discs that Zimmerman offers the public as aftermarket discs, so the allowances listed above may not be the same. But, the Zimmerman aftermarket x-drilled & slotted rotors have been reported to crack more readily by several owners who have installed them.
I'd measure your discs now w/ a micrometer and if inside the minimum allowance for the OEM disc, keep an eye on them for cracking, such as when you wash the wheels etc. Replace as soon as you see any cracks between holes forming. If outside the minimum allowance, I'd think about replacing them for safety's sake.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
