Old 02-19-2008, 08:46 AM   #1
victoreric
Originally Posted by easyc
Im curious to what happened too... Hows your coolant look? Oil? any Leaks? Will it start in Flood mode? Id say first step is to take the car to a second opinion. Also you can get a remanufactured Engine from Porsche in the sevens if you find a good dealer... the labor shouldnt cost you more than 2000, but more like 1500...
3.4 is basically a direct swap. The 3.6... not so much, although Im doing one right now. Its the swap were your 02 will need an upgrade to the 7.8... check out renntech.org for more info.
I did a search on renntech. Sounds like a lot of people are taking the engine from a 996 instead of the boxster. Is this what you meant? I was thinking of maybe taking a Boxster S engine. Anyone know which one would be easier? Pros/cons?
02' Seal Grey Mettalic Boxster
www.victoreric.com
victoreric is offline   Reply With Quote
