Old 02-18-2008, 01:31 PM   #2
insite
here's my preferred setup for a street boxster:
Front Sway: M030 'S'
Rear Sway: M030 'Base'
Springs: M030
Struts: Bilstein Sport or M030
the reason for the base rear sway is that it's thicker than the S and takes out some understeer. a primary reason i love the M030 springs is that while Eibach and H&R lower the car evenly, the M030 lower the car more up front. again, this takes out understeer.
the bilstein sport (and HD; they're damped the same) are supposedly a bit more stiff than the M030, but i can't tell the difference. either is great.
the eibach sways are almost identical to the M030 listed above, but twice the price. the H&R sways are WAY too stiff for the street and will be underdamped by M030 or Bilstein struts; your car will porpoise.
Essentially, if you buy the full M030 kit and have them swap the front bar to the S M030, you will have a full package that works very, very well together.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
