Old 02-12-2008, 04:12 PM   #4
insite
Originally Posted by rick3000
I finally got some time, and checked the front radiators today. They are completely clean, there is nothing wrong with them. Which, from what I have read narrows it down to three things the engine fan fuse, right/left radiator fan fuse, or the coolant.
I checked the coolant and it is about 1" below the minimum mark, which is bad. According to the guy I talked to at the Porsche dealer, if the coolant level is low the engine could be heating up more than the gauge is showing. Is that true?
Also, should I just add coolant, or should I flush it?
Thanks!
don't worry about the low coolant; what the mechanic is talking about only occurs when the engine is full of vapor rather than liquid. this only occurs when you're almost out of coolant. if there is any coolant in your reservoir at ALL, this is not occuring.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
