Old 02-04-2008, 08:32 AM   #3
insite
Originally Posted by paultither
Its a 1997 with 96,000 miles! Quite a lot!
We have a thing in the UK called an MOT where, when a car is over 3 years old it has to under go checks to make sure its road worthy.
This was one of the things they pointed out to me. The fact that there is excessive play in the ball joint on the front outer suspension arm and the rear lower outer suspension arm.
If I give you this link to the website where I buy my parts, could you guys point me in the right direction to the exact parts I require. (part number)
This would help me out so much!
The link is www.design911.co.uk - under the suspension & axle section.
here are their part numbers:
ID99634105316X 986 LOWER CONTROL ARM (DIAGRAM A No.7) £ 179.50
ID99634105316W 986 MAIN LOWER BAR (DIAGRAM A No.8) £ 179.50
the actual porsche part number for a is 996.341.053.16 for both the front and rear parts.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
