Old 02-04-2008, 06:24 AM   #1
insite
Originally Posted by paultither
Hey guys,
Got my Boxster back from Porsche with the following problem:
N/S (passenger side UK) rear lower outer suspension arm has slight play in ball joint.
N/S (Passenger side UK) front out suspension arm has excessive play in ball joint.
Which part do I need to buy to solve this problem? Can you buy seperate ball joints and link rods or do I need a whole new control arm?
what year is the car & how many miles? does the suspension squeak? does the car shimmy when you drive it? my guess is you probably really don't need any parts. at any rate, the two parts are identical part numbers and will run you about £280 each without installation. if there are no symptoms, i'd leave the old ones in and forget about it.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
