Old 02-03-2008, 02:38 PM   #6
saaber
Originally Posted by pompous
My coolant is low and I don't know what it has in it. I need to add some more coolant so the light quits flashing. Will it be ok if i just put some zerex and be ok??
Also check under your carpet inin the trunk under the tank for coolant. As you may know, a cracked coolant tank and resultant leak is almost a certainty at some time of the boxster's life.
saaber is offline   Reply With Quote
