Old 02-01-2008, 11:32 AM   #4
joshua6060
Hey, when I went home for lunch, I jumped started the car using the bolt that holds the negative cable to the chassis, (had not read blue2000s's post until now)
My logic was that this is clearly a bolt attached to the frame so it seems safe to me as previous post suggested finding a bolt to attach the negative clamp to.....
It started right up, drove it to run some errands and back to work, probably a good 50 minutes total. Hopefully I won't be stuck in the parking lot after work.
blue2000's post "Don't use the bolt that holds the negative cable to the chassis, it's right next to the battery"
joshua6060 is offline   Reply With Quote
