Old 01-28-2008, 10:35 AM   #13
CJ_Boxster
Send a message via MSN to CJ_Boxster
As for my excessive Toe issue, im going to try to trim off some material from the ecentric washers to give me less + toe and more negative... I dont like the way the rear end reacts to bumps in the road as a result of the excessive + toe. The rear end will have a shimmy or wiggle when one wheel hits a bump...
for instance, the drivers side rear wheel hits a bump, the rear will sway to the left what feels to be about a half inch, then as the driver side wheel comes back to flat level road, the the rear-end will sway back about half an inch or less. and vis-versa if the Passenger rear wheel hits a bump.
So what ill do is trim some material off of the shortest end of the ecentric washers to get me closer to acceptible toe range.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
