Thread: Won't start
Old 01-21-2008, 01:38 PM   #1
porschedude
it's a bit strange if you don't hear a sound. is the headlight pretty bright when turned on? sometimes battery may be weak even though all electrical stuff are working. obviously, it is electrical or no gas issue. could be battery, bad clutch switch, or bad gas pump...try jump starting for a few minutes. otherwise, try to push start. could also be bad ignition switch but you will usually have other symptoms like weird wiper or headlight operation etc. let us know.
porschedude is offline   Reply With Quote
