Old 01-17-2008, 10:14 PM   #6
boxs2000
Originally Posted by djomlas
im about to get a new wheel, i already got the steering wheel hub from Momo, and my question is what do i need to remove and then install the hub, what tools?
also, what precautions do i need to take in order not to have the airbag blow up n my face?
thx, DJ
Make sure when you disconnect the battery that you wait a few minutes to let the remaining juice(power) in the car drain also make sure you touch a metal part of the car like the door jamb or ignition switch that way if you have any static electricity on you it discharges and you don't set off the airbag when you go to disconnect it. Out of curiosity, does the MOMO set up you are doing have an airbag? If not won't your airbag light stay lit?
boxs2000 is offline   Reply With Quote
