Old 01-17-2008, 10:04 PM   #1
boxs2000
The wing mounts by 2 bolts on each side of the support and another hole is drilled on the passenger side for the 3rd brake light located inside the wing. The factory 3rd brake light on/above the trunk is removed. The factory also unplugs for the spoiler that goes up and down. Installation looks fairly straight forward I can take a picture of the bolts from underneath the trunk if you are interested. I did not install mine, it was factory option.
boxs2000 is offline   Reply With Quote
