Old 02-11-2005, 02:13 PM   #14
IceBox
Crazed P-Car enthusiast
That's just it, Wetstuff: Some folks just plain don't have enough to worry about, so they invent little concerns, then agonize about them all out of proportion to whatever circumstance the issue is. Instead odf applying the simple logic that if you can afford the car, you can probably afford to fix it, or conversely, if you can't really afford the car, buy something else, some folks need to over-reach, which almost always leads to bad times. So it's simple...do some research, figure out what you can afford, taking into consideration that cars break and need to be repaired, buy the best example you can get, put the top down, and all those worries will dissappear. And remind yourself every so often, as Wetstuff aptly points out, that we're all pretty lucky if your major concern is pulling some cash together to buy some nice bulbs for your Boxsters' headlights
P.S. Mr. Lee, I only point your skill-set out to fairly warn any contrarians what's in store if they get outta line. They way you took revenge in the Chinese Connection should insure that any comments, pro or con, will be couched respectfully. I...I just don't want to see anyone get the beat down!
What's behind me does not matter.
IceBox is offline   Reply With Quote
