Old 01-07-2008, 04:15 PM   #5
Paul
Porsche "Purist"
Paul's Avatar
If you push the brake pedal down an inch or more, the master cylinder piston is pushed past the inlet hole from the reservoir. This will keep the fluid from draining.
I sometimes I jam a screw driver under the gas pedal over the brake pedal and under the clutch pedal.
Or sometimes I use an ice scraper (piece of wood, etc.) jammed between the driver's seat and brake pedal.
1987 924S. 2002 996TT. PST-2
