Old 01-03-2008, 06:38 AM   #1
SRQ Boxster
Originally Posted by David N.
Hmm, my high beams and low beams are the same bulb. It just raises up for high beam. I thought that's how all of the xenons worked.
-David
The Litronics use two different bulbs, a low and a high beam. When you operate the high beams, there is a mechanical deflector for the low beam that raises up a few degrees to help fill the space or gap on the road in front of you created by the high beam being aimed farther down the road. This gives the illusion that both bulbs are the same.
SRQ Boxster is offline   Reply With Quote
