Old 12-31-2007, 11:12 PM   #1
blinkwatt
Send a message via AIM to blinkwatt
Suspension Install Questions
Alright so I can't seem to find anyone to install springs for a reasonable price so I'm going to do it myself.I could really use your guys help. Please where you know the answer(s)
-What special tools will I need?
-Does the whole front/rear need to be lifted while working or could I just raise one side at a time?
-From what I've seen after you remove the front spindle nut you should be able to remove the strut assembly by pushing the shock down correct? Where will there be space to push the shock down? The directions in the Bentley and on Renntech say to push down....push down on what? The top of the shock located where the 3 nuts are moved?
That's according to these directions;
http://www.renntech.org/forums/index.php?showtopic=7073
-I've seen 3 or 4 different ways of taking apart the rear. Mladen,what's different from the front and rears?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
