when my battery died I opened my door and then couldnt close it because of the window being up. What you have to do is this, in your fuse box there is a yellow fuse pull it out connect your jumper to it positive then ground on the door hinge and that will give you the current you need to pull it down a bit. This is assuming you have no current, if you do and your window is not moving then it is prob definitly the fuse.
